You wouldn't normally sink the back box in to the full depth, but set it to finish a little below finished plaster level. And you wouldn't be channelling the wall to the same depth as the box. Otherwise the wall would be seriously weakened.
If you're just putting in cables, why make the channel so deep? Perhaps make it wider instead if you've got lots of cables in the run? As per regs, with a 100mm inner leaf, 33mm max deep for vertical chases, 25mm max deep for horizontal.
This is purely a fictive post, based on curiosity and having read the EI Guide to the building regs can't find anything definitive regarding back boxes.
Seems strange that they have made rules for chases, but there does not appear to be anything of clarity regarding boxes and the accepted depth of wall to sink them in to.
doh!
serves me right trying to be too quick off the mark.
Anyway, OP, clearly it's ok to make holes, even big ones, right through a wall, so there's probably no limit to how deep you can have a back box. It's the structural weakening effect of a long channel in the wall they're trying to avoid.
