Building work involved in a garage conversion?
NHW
21 Jun 2013
I am thinking of converting our external/detached garage into an office/playroom, i have spoken to the local council and no planning permissions will be required, just building regs.
There is about 13m2 in the garage which i think is quite a nice amount of space for an extra room, if it was anything less than about 8m2 then i probably wouldn't be bothering. Bearing in mind that this is to convert the entire usable space, i think some people have done conversions where they did half of the space and so still left with enough room to open the garage up and use it as storage, but that wouldn't really apply in my case.
The only things i can think of for the conversion would be:
  • Raising the floor height to allow for insulation over the concrete slab
  • Fully insulating walls and ceiling
  • Providing heating and cooling for the space, either by tying into the house’s main system or adding an independent one.
  • An electrical service upgrade to accommodate the larger load
  • Replacing garage doors with fully insulated stud walls
  • Adding windows and doors
bearing in mind that i would prefer to keep the garage door as it is and not brick it up, most likely just put up a stud wall right behind the door.
Is there anything else that might be involved in this kind of job? Thanks
Possibly mechanical extraction depending upon use.
Provide venting for the loft space.
Smoke detection maybe an issue but unlikely.
Foundations will need to be inspected should you decide to brick up the garage doors.
