We are about to install a new cooker unit and separate microwave. We have removed the old double oven unit and have found that the connection is direct into the cooker from the cooker point( isolating switch). So, now the problem part.
We have bought a Neff B1451 single oven unit with a rating of 2.8kw( no cable or plug) and a Neff B77409 Quantum speed microwave combi oven with a rating of 3.6kw (has a standard 3pin plug attached). Both units in the instructions say they must have an isolation switch. Presumably the oven has a similar connection system to the one we disconnected from the old oven. (We haven't looked yet as the oven is still in the packaging)
So, how do we connect both units?
We assume we can wire into the back of the oven and use existing switch. But the microwave is the problem, we assumed this would be plugged into a 13A socket but the loading for the microwave is 3.6Kw.
Help
Help
