Bulbs for downlights
26 Jul 2011
Sussex
I have several downlights in my bathroom all of which currently have 50W GU10 halogens fitted.
3 of them are set in a plinth over a mirror and the other 3 are in a 3 light fitting in the centre of the bathroom.
Can anyone suggest the best low energy bulbs to switch to that will give a similar light?
TIA
Have a look for 5w LED lamps.
Expect to pay around £10 per lamp.
Even 5w lamps are still not as bright as a 50w halogen, but there as close as you're going to get just at the moment.
They are IMO a good replacement for halogen lamps though.
Forgot to say, you will want warm white lamps if you're replacing halogen and you want to keep it looking the same.
Plans B & C:
http://www.thornlighting.co.uk/download/Base_LED_Brochure.pdf
http://www.thornlighting.co.uk/PDB/Ressource/teaser/E2/TLG_BaseLED.pdf
http://www.thornlighting.co.uk/object/PDF/datasheet.aspx?CompanyID=7&GroupID=12650&CL=E2&CC=GB
you can get 7W LEDs, but be careful, the ones I have seen wont fit a standard fitting, as they are around 75mm long.
Ceiling mounted torches are not a good way to light up rooms.
A good thing to do is to replace them.
A well designed downlighter installation is a great way to light a room. There's no point wasting money on replacing the lighting when there's nothing at all wrong with it.
