Hi all - I'm buying a property which was built around 1895.
Its a terraced house, but as you look at the property from the front, the left side of the house has an alleyway giving access down the side of my house into the back garden.
Along this wall used to be a door which at some point in time has been filled in with brick, and a lintel is present.
Therefore, the wall of my house along this alleyway is directly above the limit of the cellar.
The problem is, is that when you go into the cellar, is the brick wall in the cellar that is directly below the wall as described above, and there is a large "bulge" that is roughly 5-6 ft long in length, and maybe a couple of ft high. The extent of the bulge away from the wall is hard to measure, but if you was to imagine a big blister, then its bulging by maybe 3 inches away from the level of the wall.
Now, as the purchasing of the house is only in the early stages, and the surveyor still has to do his checks, what does anyone suggest about this problem? I have a good builder who has recommended a course of action, but has anyone else come across this type of problem, and if so, how critical was it?
Any info or help would be greatly appreciated.
Thanks Wardster
Thanks Wardster
