OK last time, for the extremely hard of thinking:
Good answer, it is of course incorrect.
The use of force as it relates to self defence (common law) is different to the use of force for making an arrest (statute).
- Self defence: threat over / no more force
- Making an arrest: perpetrator still at large / reasonable force can still be used, even if they are running away.
Surely you can see the difference?
Nor have I argued differently. Nor is that anything to do with chasing someone with a weapon after the threat has passed.
This applies to the common law excuse of self defence only. With regard to making an arrest - There is no obligation to cease the use of reasonable force, just because the person is running away or the immediate threat of violence passed. As has been said by BB barrister, your own link and the actual CPS guidance, as well as me. Further, nothing prevents you from using an object as a weapon, when pursuing a criminal who you suspect is probably tooled up, so long as this is based on a reasonable belief and you goal is to catch them before they get away and the police arrive.
Which is wholly irrelevant to the Criminal Law Act 1967 and irrelevant to and nothing to do with the fact that it is not lawful to chase after a suspect with a weapon once the threat has ceased.
There is nothing that prevents you from pursuing a suspect and using reasonable force to apprehend them including the use of an object as a potential weapon
Nor will you be able to show otherwise. Nor have I mentioned common law, I don't know why you keep motioning it being the 'wrong law' either nor is relevant to this....
the right to use force to defend yourself is common law, sorry you don't seem to understand that. If you read
https://www.legislation.gov.uk/ukpga/2008/4/section/76 its in black and white.
This common law right to use reasonable force is entirely different to the statutory power to use reasonable force to make an arrest as per section 3(2).
