D
Diy-mañana
Following up on the locked thread by East61 and not wanting to hijack any existing threads i started this new thread.
We have buteline in our 4 year old property (new build) the buteline supplies h&c water only no heating (all electric).
The fault we have is some of the crimped fittings are leaking,this has been blamed on the installer for not correctly calibrating their crimp tools.
Other fault is the hot water flow slowly reduces to a trickle when running bath or shower,the developer has changed the mains uv cylinder but still the same.The fault,after 3 years of diagnostics is the bend radius is either to tight or the bute is kinked under the screed.
The builder/developer has agreed to replace all the butepipe with a different maker of plastic pipe.
What make of pipe is preferred by the tradesmen here ?.
Thanks in advance.
(PS the butepipe has not failed,the installation method is at fault).
Thanks in advance.
