I have a TurboMax VUW282E which has given many years of good service, however over the past week it has developed a problem with the DHW supply.
When drawing hot water the boiler starts as normal but then after about 15-20 seconds shuts down and then after about 7 seconds starts up again. This happens even when there is full demand for hot water. The water is reaching temperature but then of course, when the boiler shuts off, the temperature slowly drops until the boiler reignites. Which means you get a supply of hot water fluctuating from a good supply of hot water to just warm and back up to normal again.
I have ruled out problems with gas supply, burner, DHW microswitch and the diverter valve. The boiler is running perfectly for the CH reaching temperature, modulating etc.
Setting the hot water temperature control high or low makes no difference. The flow from the hot water taps is fine we have no thermostatic showers or anything like that.
I have concluded that it must be a problem with the DHW heat exchanger, the overheat thermostat or the water section diaphragm. The boiler is not making any funny noises so I don't think the water on eitherr side of the DHW heat exchanger is getting too hot and boiling.
I have read many threads where it has become and expensive trial and error replacement of components to eventually cure the problem and I want to avoid this scenario if possible. As the boiler is now over 12 years old I suspect that many engineers may not be familiar with this model.
Does anyone have any idea of how I can work out which component may be at fault or give enough information to a plumber so the fault can be quickly discovered and rectified?
Many thanks
Many thanks
