I unscrewed the frontplates from our oven/hob switches so I could plaster around them and the chases (CU off). The wires are quite short so they only come out 15-20mm or so. Circuits are new and were installed about 4 months ago.
After plastering, when I screw them back one of them buzzes, and the other one cuts in and out a few times every second.
The buzzing one, if I unscrew it and let it sit away from the wall it doesn't buzz, or at least if I move the frontplate I can stop the buzzing. So I assume I've loosened some of the wires inside when I was moving it to plaster?
Should I just get this checked by an electrician, or can I try to tighten up the wires as if I was fitting a replacement frontplate? I'm fine with wires, but they're a bit fiddly as they're so short, and I'm not keen on the whole 'death' thing.
