I am having the following problem.
C.H. works fine with no problem at all.
However the DHW is doing strange things...
I need to have the hw tap on a very fast flow before the boiler responds with the lights running across the front and the flame light lit. It I then drop the flow rate to a point where the water is hot ( not scalding hot ) the boiler responds by reverting back to CH mode ( or off if the ch is not on ) This results in cold water at the hot tap... Not what is required !
If i give it another go with the flow rate the whole sequence repeats.
Could this have anything to do with the sold water pressure as I have recently had a new stopcock fitted. Or is there a more sinister fault lurking...
The temp control is fully clockwise.
