- Joined
- 16 Jul 2006
- Messages
- 1
- Reaction score
- 0
- Country
Hi
I am trying to cable a pond water pump and filter to an existing consumer unit in a block of stables. The estimated load of the pump is 300W and the filter 100W. The pond is 10m disrtant from one end of the stables which is itself 20m distant from the consumer unit making a total cable lenght of around 30m.
I am planning to run a radial circuit using 2.5mm twin/earth cable inside the stables (20m) and 2 core SWA cable from the end of the stables to the pond in a trench 600mm deep (10m). I aim to use a spare way on the consumer unit and use a 16A MCB
At the point where the twin and earth meets the SWA I am planning to use a metal box and also have an MCB both for safety to to use for isolation.
What I need to know if these cables will comply with the regulations. There is no insulation, grouping or excess temperature factors to be taken in to account with the cable calculation but I am not sure how to work out the cable load when there are two different types of cable.
Regards
Jules
Regards
Jules
