Whether designed for it or not, installing one on a typical domestic supply is likely to be impossible.So how is it meant to be installed? Its designed for domestic use?
The storage heating situation is not comparable, as they only operate at defined times, typically at night when the load on the network is significantly lower.
Why would anyone want to heat an unoccupied property?Was intended to heat the property prior to being occupied.
Even if this was required, what will be the heating source when the property is occupied later on?
