- Joined
- 22 Jan 2007
- Messages
- 8,525
- Reaction score
- 4,535
- Country
Hey all.
Looking at potentially getting electric car next year and nearly ready to put floor down in my hall.
At the moment my CU is about 2.5-3m away from the outside wall where I would have a charger fitted, but I need to dig a bit outside and feed either a cable or conduit under the ensuite in between the CU and outside wall before I put floor down to avoid lifting it all back up later.
Question is: is it more likley an electrician would use SWA directly to charger or T&E in a conduit to a gland on them? I've seen charger installs but never paid much attention to them, cable would have to come out at low level and surface run upto height of charger, and ideally I'd like to not have a junction box on show just under it.
but not sure if SWA can terminate directly into typical car chargers or how its done.
I suppose I could run conduit anyway and they could run whatever they want through it, but I've typed this much so may as well ask!
If it make any odds would be a 7kw charger so I'd imagine 6mm cable
