Cable Runs!!
S
scotteng
hello
I need to run some cables down a square brick pillar, to feed a kitchen island sockets. The cables will be plastered and will not be inline of the sockets, so my question is
can i run cables from ceiling to the island if they are kept within 150mm from the edge of the wall, or does that only apply to internal corners? or will it be a case of earthed steel conduit??
cheers in advance for your help
can you put a socket on the pillar anyway?
just to show a cable is present?
i was hoping to, but customer wants all sockets hidden away in cupboards, which are not in line with the pillar!! which is a bugger
I'd run a cable or containment system that permits wiring to be installed outside of the safe zones, as I think the 150mm rule is a bit of a grey area in this case. I suppose technically it would be permitted to run unprotected cables within said zone, but common sense says it's a bad idea.
What's he going to use them for if they are in cupboards?
And why are so many people so ******g thick that they cannot grasp the simple concept that a kitchen is a place of work?
tell me about it!!! the whole kitchen which is a fair size has only one socket at work top height!! crazy, ill be expecting a call in a few months to add a few more!! the sockets in the cupboards is just stupid, so much work for something that will never be used! hey ho
Kettle
Mixer
Food processor
Hand-held blender
Toaster
Subject to your take on accessibility, and whether they should have isolators above the worktops, you can put sockets in cupboards for fixed/static appliances, but when he wants toast with his tea which will he put in the cupboard - the toaster or the kettle?
If he's that pathetic that he doesn't want sockets on his precious walls why doesn't he use those jobbies that sink down into the worktop when not needed?
Yes you can. The On Site Guide states "vertically within 150mm of the angle formed by two walls" so the choice is yours.
Sockets in kitchen cupboards is pointless but if it's what the customer wants... :)
But that would spoil his precious worktop. ;)
