Hi all, I have a 6kw pottery kiln single phase 240 volt,I have a 40amp fuse on the supply end and the kiln on the other with a 45 amp switch cut into the circuit,the cable will be approx 5m in conduit under concrete and 5m in conduit above ground .
As it will be running for about 10 hours at a time can anyone advise me on the cable size I should use,My calculations lend me to using 6mm t&e or should I use the 10mm t&e?
Any advice would be most gratefully received.
Many thanks.
F.T.D.
xxxx
Many thanks.
F.T.D.
xxxx
