Cabling inside fluorescent cat2 fittings. PICS
18 Jul 2004
Devon
See this so often......
Crumbled terminal blocks and T & E stuck next to a ballast....
I have had that many times. The worst was when an emergency fitting needed re-lamping. I switched the light off but not the circuit. As I took down the louvre one of the edges touched the permanent line connector which had crumbled. BANG !! (luckily the earth fly lead was attached)
Its probably due to the ultra violet given off by some types of lighting tube, as I have encountered this problem before, where a connector block has become brittle in a lamp fixture.
Seems to have a similar effect on some cheaper brands of starter.
Don't you just hate it when they turn to dust in your hands?
