T
timmyquick
Hi all
I am finally calling an electrician next week, to sort out having no earth connection. I have posted a lot of questions on here lately, so thanks for all the replys. I have been trying to put a lot of the dodgy diy electrics right, so there is less for the electrician to find fault and charge me for repair. So have been checking suspect wiring as well as making a few additions myself. What i would like to find out now is if this is acceptable.
Checked my kitchen wiring. It is supplied from a 32 amp MCB. Not sure of cable size guessing its 6 mm could be wrong may be bigger . This runs into the kitchen loft then into a JB. From this 1 FCU is connected to JB in 2.5 mm for combi boiler. Then another 2.5mm cable to a socket which is actually located in living room and another 2.5mm cable to a socket in the kitchen. Is this acceptable or will this need changing?. Also the socket in the kitchen has had a spur added to it which runs below the worktop to another socket for the fridge is this allowed? i can tell this has been done after as there is no earth sleeving for it.
