I recently moved to a property that has oil fired central heating so have no experience in this,always had gas.I have a problem with my boiler as mentioned below.
I have the timer set up for the hot water to come on twice a day.
The boiler fires up ok but then switches off after a few seconds,then comes on again straight away,then off again.
This carries on for twenty mins ( it is set for 30)the short bursts of it being on varies,5,10,20 secs.
Any idea what is happening ?
Is it safe or damaging the unit.it is heating water ok.
It was serviced few days earlier and up to that point the boiler would fire up at the set time and run for some time before turning off.
I have called the engineer out but cannot get here for a few days.
The boiler is sited about 10 feet up an external wall so is a bit difficult to get at if like me you do not know what you are doing.
The original was installed in 1998 but has since had various parts changed as far as I know.
