I am considering having a false chimney built to allow me to have a balanced flue type of gas fire installed with the flue exiting outside at 7 - 8 feet height. This is necessary as the exit cannot be at floor level due to the passageway being too narrow and my current chimney does not comply with regulations.
I live in a ground floor conversion flat which has had a false ceiling installed about 10 years ago to cut down noise transmission from upstairs - the conversion included little if any soundproofing when it was done. It has been largely successful but there is sometimes some sound from the tv upstairs, depending (I think) on exactly how close the tv is to the wall - this I presume varies when cleaning/dusting leaves the tv in a different position. The sound is being transmitted via the wall and my fear is that a false chimney attached to that wall could act as an echo chamber and amplify any sound. This fear may be totally unfounded, but I would be interested in any thoughts on this.
The chimney will be plasterboard, installed by the gas fire company and the fire will be installed by a registered gas fitter.
Thanks in anticipation
