I apologise for the length on this post in advance.
I have a noise that sounds like boiling water at the boiler a Veissman 100 WB1B on an open vented system. Once the boiler has modulated down after about 10 minutes or so it is a quiet as normal.
There is no Magna clean (or equivalent) installed.
The boiler is approx 7 years old.
The noise started March last year, there had been no changes to the system since the boiler was installed and has worked perfectly until this problem started.
I had the system powerflushed last June by the gas engineer who installed the new boiler and has serviced my gas appliances for many years. He didn't think that the powerflush was needed but I asked for it anyway to eliminate any corrosion or sludge that may be present. The noise persists to this day and now the boiler has started noticeably cycling which it never did previously, there is also bubbling that comes from one upstairs radiator when the pump kicks in. I have been bleeding a lot of air from this radiator once or twice a week.
I have a British Gas break down contract and asked them to take a look at it. The engineer said it was crud, he implied that the powerflush wasn't done correctly and needed doing again. They quoted £750 for that.
I had the pump replaced as a possible source of air as it was 9 years old but problem still persists. My gas engineer has had couple of attempts to cure this but I think is stumped.
I realise air is not good in a heating system, corrosion etc. I'm at a loss as what to do next.
Is there no one that can help me with this?
