Can anyone name these radiators?
28 Oct 2026
Hi everyone,
I’m hoping someone can help identify the manufacturer and model of two designer radiators installed in my house around 2022.
Both are anthracite, double-row radiators with rounded elliptical-profile tubes.
Radiator 1 — Vertical
  • 1800mm high × approximately 430mm wide
  • 6 tubes front, 6 tubes rear (12 total)
Radiator 2 — Horizontal
  • 600mm high × approximately 840mm wide, including the small end fittings
  • 14 tubes front, 14 tubes rear (28 total)
I’ve attached photographs of both.
I’m having an air-source heat pump installed, and need the radiators’ heat outputs to determine whether they’re suitable at lower flow temperatures.
Does anyone recognise the manufacturer or model, particularly from ranges available around 2022? A manufacturer’s datasheet with BTU or watt ratings would be ideal. House is near Hedge End, Hampshire
you wont get the exact maker as there is dozens of suppliers of those types of rads and no markings on them
So have a look here for same sizes and the outputs will more or less right
