This may be a strange question.
Is it acceptable to have an electric shower in the same shower cubicle as an overhead fixed mixer shower or is this not allowed?
That's something I'm planning to do - having found (after the failure of the electric one) that my combi does a shower just fine, the plan is to put a proper thermostatic mixer in to replace the "temporary" (
) extended hose currently running from the bath mixer taps.
We do want to replace the electric one though, as we have no stored hot water, so if the boiler ever packs up an electric shower would be the only way to get a warm wash.
I share JohnW2's concerns, so if I can't come up with an acceptable (performance
and appearance) way to protect the electric shower then I won't have an overhead outlet, just a demountable head on a riser rail the same as the electric uses - in fact the switch from mixer to electric would be done by moving the hose from mixer outlet to the electric shower outlet.
PLAN B
Which has just occurred to me as I was typing this.
Don't have an electric shower in the cubicle.
You have a cold supply and a hot supply and a mixer.
Have an instant water heater installed remote from the shower cubicle, with a diverter valve in the pipework, so that you supply the mixer with hot water either from the normal supply or from the electric heater (assuming that this whole thing is about having the electric as an emergency alternative).
I like this idea.
