There are 10 outlets on the board and 20x2.5mm going into the bottom. Make sense?
No.
Not all circuits use 2.5 mm2 cable.
Firstly you need to determine the size of the fuse or mcb at the consumer unit which serves this circuit.
that I strongly suspect it's only benefit of doubt at this stage which stops you from being branded a wind-up merchant.the colour of the mcb is a light grey colour if that helps?
trickymicky69 said:Its only the boiler on that circuit atm
Well - Part P applies to the work no matter where it is.As to Part P I have seen no reference to location so this is unknown.
