Can I fit a plume management kit on the flue myself?
5 Jan 2024
Or can I do the install then call a gas safe engineer do to a Gas Safety Record cert?
No. Modifications to the flue must only be done by a Gas Safe Registered engineer. A plume management kit could significantly affect the combustion of the appliance and so requires the use of a flue gas analyser and possible gas valve adjustments before the appliance is put back into use.
North Manchester
It’s also a logic heat 2 H12 boiler.
Anyone who wants some work hit me up
Why don’t you call the installer who fitted the boiler
Post a picture of the flue, some gas installer ( short of work) might quote to do the job
I did - they don't serve residental customers - it's a new build
