Can I fit a pump to the domestic hot water system?
31 Dec 2003
In my old house there was a separate pump on the DHW system that ensured hot water was available as soon as a tap was opened. I've moved house to a recently converted barn. It's been built to a high standard but it's a large house and it takes ages to get any hot water from the taps.
Can I fit a pump retrospectively or does it require major surgery to the plumbing? There is an OSO hot water cylinder in the airing cupboard on the first floor.
But they do have a secondary return connection. This is what Snowsride needs to utilise.
EDIT: Just checked an install manual I have and you can fit a circulation pump on the secondary circuit, with an NRV. :)
