Can I fit an expansion vessel anywhere on the circuit
20 Oct 2010
Lanarkshire
Hi my brothers combi boilers diaphragm has burst and its at the back of the boiler which is built into kitchen units so I said just size it up and fit on the heating circuit some where accessible, any reason why not .
1 Nov 2021
No reason why not, just fit it in the return side of the heating system.
15 Aug 2010
Livingston
How do you know it has burst, possibly just needs re-charged,
4 Oct 2012
East Renfrewshire
Lots of water or just a little? An EV will always have a little moisture on the dry side.
If fitting and EV, size it correctly and fit it as close to the return at the boiler as possible to minimise the amount of heat it's subjected to.
20 Oct 2010
Lanarkshire
A lot of water I can just get in to test the valve not just a weep also definitely burst as it blows off at the prv when heating is on and water heats up and expands
4 Oct 2012
East Renfrewshire
The prv would still activate even if it just needed re-pressurised too, hence checking if the valve passes lots of water. If it does then it probably is burst and needs replaced .... don't forget to isolate and empty the internal vessel.
15 Aug 2010
Livingston
means nothing , re-pressurise properly, if EV is indeed burst you wont be able to pressurise it and you will hear the air bubbling into it, about 1 in 50 failed vessels actually need replaced , the rest just need charged properly , not just by trying to pump them up
