If you know that why do you think that a 3.4kW load is OK to be plugged in?i know it should be up to 3kw to plug in.
You could add a 20A Control Switch as spur from the socket you wanted to use (providing the socket is part of a ring circuit) and wire directly the cooker to the switch.
NO YOU CANT!!![]()
Please don't post advice unless you know what you are doing, what you just proposed is dangerous and likely to cause a fire!
Sorry, but this is what my electrician has proposed to do for my cooker position.
Can you explain why it's dangerous?
That would be 2kW to the 17th edition!can i get away with plugging it into a socket,i know it should be up to 3kw to plug in.
And can BAS please explain why it is illegal?
which law were you referring to?![]()
