P
plymouthfury
hello to all,
i have a trianco eurostar 90/110 oil boiler, the boiler can be used with many types of flue.
what im trying to understand is why i cant make my own flue based on the spec of the boiler.
i wish to place my boiler next to a external wall with either a flue going through the wall at boiler height or a little higher at 2 metres say.
now ive had a heating engineer out to view the boiler and he says i cant make a 5 " stainless flue with a 2 metre verticle pipe followed by 90 degree shallow radius bend onto another 600 mm horozontal pipe exiting the wall with a wind shroud to protect from wind gusts.
at first he said i couldnt do it, then we discussed how the pj boiler worked which is fan driven and he then decided my flue would work, a little confused hearing i cant do it followed by i can from the same engineer.
the balanced flue system i can get (but costs far more than its worth) reduces my exhaust down to 4" with the remaining 1" used for the fresh air intake, i read articles here saying that their boilers fail with seals and if they take of the air pipe that the boiler then runs fine, this means the 4" part of the sealed flue is all thats being used for the exhaust, if this is the case why cant i make a flue the same. ie a 5" flue without the fresh air intake (as mine can draw elswhere) i cant see the difference.
the pj has a fan and therefore would push the gases out, all i wouldnt be doing is using a air intake from the flue as in a balanced flue for example.
i have a freind who is a gas engineer and he will set up the air and co once everything is installed to tune it all to work.
so my question is why cant i do this and if i cant could someone tell me why and sujest a way i can do it, i am an engineer so farication isnt a issue but i woulldnt want to put my life or others at risk.
if i speak to anyone they all say oh no you have to use the right part and nothing else but dont know why.
at the end of the day everything we buy is made by someone and i really dont want to spent 300 pounds on a flue kit i can make for 50 pounds
any help or advise would be gratefull and if anyone has a balanced flue kit i would be interested in buying it
thnakyou
thnakyou
