I want to add some Fernox into my central heating system. I have an unvented system. The easiest way to get this in the system would seem to be in the top of the towel rail in the bathroom as you can screw out the the valve where you bleed it leaving a sufficiently big hole to pour the fernox in, without any water pouring out all over the place. The other main radiators all have bleed valves on the side and have smaller valves so it would be difficult to get it in there. My only concern is that the towel rails heat up when the the hot water is selected on the timer, rather than the central heating. Does this mean that the towel rails are connected to the domestic hot water supply? I don't want to end up putting fernox in, only for it to come out of the hot water taps.
