Can I put up stud wall rather than box in bathroom pipe work?
17 Jan 2018
Hi folks,
The bathroom pipe work in my flat goes along 2 walls of my bedroom and is boxed in. I cant put any furniture against these walls and ideally I want to put up 2 stud walls so I can use the space (I’d rather not have a built in wardrobe around the pipe work). However a friend told me they believe that the pipes need to be left accessible, giving the example that if they were under the floorboards they would be accessed by lifting a floor board and a stud wall would prevent access. Is this a building standard requirement? And do you think the stud walls are a good or bad idea? I don’t wish to build shelving around it as I’ve nothing to shelve, much prefer to put my furniture against the wall but I won’t if it’s not advisable as I want to sell the flat on eventually.
Any advice appreciated.
Thank you.
In a flat the floors are often concrete with pipes buried in Concrete walls also have pipes fitted within them.
Just try to avoid any joints in the hidden area.
This stuff is regulated not by the building regs, but by the separate "water regs".
See:
https://www.wras.co.uk/consumers/advice_for_consumers/what_are_the_water_regulations_/
http://www.legislation.gov.uk/uksi/1999/1148/made
http://webarchive.nationalarchives....y/wsregs99/documents/waterregs99-guidance.pdf
In the last of those docs, see G7.1 on page 14 and figure 3.2f on page 18; inside an internal stud wall is OK.
Your friend is basically correct that pipes must be "accessible", but the threshold for "accessible" allows removing plasterboard from a wall
If lots of joints, then best left open. If just lengths of pipe with joints at the end or branches then can be built in.
Thank you. There aren’t many joints and it’s water pipes (waste and potable) Consensus is stud walls, one with a vent for access.
Cheers
