Can I replace O ring on Grundfos UPS2 15-50?
7 Apr 2016
Camberley
Hi, Could anyone tell me, if one is able to obtain a replacement o ring to go between the pump head and the body?
I've done a small amount of hunting online but no luck in finding a part no....
(I ask this because occasionally when in the process to diagnosing a blocked pump Id like to inspect the impellers, without having to worry about the seal leaking if I were to put the old head back on after cleaning, instead of replacing the head)
Thanks in advance.
Simply Bearings <simplybearings.co.uk> stock O rings in a very wide range of diameters and cross-sections. I managed to fix a leaking water meter with one from them when I had had no joy from the manufacturer.
the seals are very reliable, I have changed countless Grundfoss pump heads and have never seen a seal leaking
thanks for your replies.
ianmcd - would you be worried about the seal leaking if you were to put the old head back on with the old seal. I too have changed many heads over but in that case would always fit the replacement head with the new seal.
The scenario I had i mind:
Friday night job, Old Dorris's down the road heating pump has packed up. No spare on the van, I can remove pump head and give it a good clean out. Put old head back, heatings back on. Question is: Is it going to leak?
removed and replaced the same grundfoss pump heads on many boilers and never had a leak, Wilo however will be like the dancing fountains
