- Joined
- 29 Mar 2003
- Messages
- 2
- Reaction score
- 0
- Country
I have an existing external wall light connected to a switch inside the house that runs off the existing downstairs lighting circuit MCB.
Can I connect to this wall light, using an appropriate armoured cable to run down the garden, to install a couple of garden pillar lamps that will work off the same switch.
Is there any additional benefit in adding a weatherproof fused spur unit to run off the external wall light.
...or should I attach to some sort of RCD !
Thanks for the advice
P
P
