Can I use an outside wall light to feed garden lights
29 Mar 2003
I have an existing external wall light connected to a switch inside the house that runs off the existing downstairs lighting circuit MCB.
Can I connect to this wall light, using an appropriate armoured cable to run down the garden, to install a couple of garden pillar lamps that will work off the same switch.
Is there any additional benefit in adding a weatherproof fused spur unit to run off the external wall light.
...or should I attach to some sort of RCD !
Thanks for the advice
P
any electrical appliance that is outside has to be protected via an rcd, so unfortunately the answer is no you can not do that.
You could run it off a plug via a spur PROVIDED it is protected by an rcd or you can plug it in with an rcd plug
