Can I use network cable for a phone line??
25 Oct 2012
Dorset
Good morning all,
I need to move my phone socket and need about 20 meters of cable. I know it's pretty cheap anyway but I can only seem to buy it in 100m reels. But what I do have is around 100m of stranded CAT 6 cable. I can't see any reason why I couldn't use it, but I don't know for sure.
Any help would be great
Regards
Stranded cable cannot be used in IDC ( punch down ) connectors as IDC requires solid cores to make reliable joints.
Son in law works on major refurbishments of commercial properties and they use Cat 6 for virtually everything
Doesn't make it right though! Plus solid or stranded?
Agree with bernardgreen if you want possibility if intermittent connection problems, including crackles, use it.
Cat6 is fine for phone lines but as others have said stranded cable will not work reliablly with punchdown connections. So you would either need to ensure you use accessories with screw terminals or join on short tails of solid wire.
Thanks for all the replies. I had the house upside down yesterday so could of done it with the standard CAT 6 but taking your advise I'll get some telephone wire for next weekend and do it properly. You can probably cut it by the meter in places like B and Q but if not, for £20 I'll just buy the 100m reel.
Also while I'm posting, I found out yesterday that old wiring for storage heaters which I've removed runs from the cupboard under the stairs (where my modem is) through the cavity walls and pops out in the attic. As I'm decorating each room I'm running between 2 and 4 CAT 6 outlets in each room which at the minute are all just coiled up in the attic. Could I get (or make with my standard cable) a 10 metre cable to connect one of my LaN ports in the modem to a switch in the attic where all the rooms wired Internet access is going to be?
Thanks for all the help again.
Regards.
In principle yes.
BUT, switches, hubs and modems do sometimes have overheating problems. These problems would be made worse by placing in a loft which can get very warm in summer.
