It can be boxed in without vents, but I wouldn't fit a complete top and bottom. Leave a good air gap around the case, also the build the cupboard so it's fully removable, these boilers need good access at the bottom
Clearances of 165mm (6 1/2") above, 100mm (4") below, 5mm
(1/4") at the sides and 450mm (17 3/4") at the front of the boiler
casing must be allowed for servicing.
The minimum front and bottom clearance allowed when built
into a cupboard is 5mm.
