    Dismiss Notice
can immersion heater empty itself
Discussion in 'Plumbing and Central Heating' started by andysink, 3 Feb 2019.
  1. andysink
    andysink
    27 Dec 2010
    30
    Thanks Received:
    Country:
    Have gas heating, switch it on to heat immersion heater.(not combo)
    Immersion heater was very hot so switched off and ran bath. turned off tap then
    went downstairs for 2 min then heard bath draining.
    Found plug had come out.
    I think the immersion had also emptied as it had no heat at all on touch and that is unusual.
    Tried again an hour later and all is ok
    Can this be more than a loose plug?
  2. Sponsored Links
  3. Notch7
    Notch7
    15 Sep 2017
    25,360
    Thanks Received:
    1,790
    S. Uplands
    Country:
    A hot water tank cant empty AFAIK, if you keep running the hot, it will just get cold
    Usually they fill from the bottom and empty from the top
    I am assuming by immersion heater you mean hot water tank?
    Im not sure what conbection the bath plug has......
  4. andysink
    andysink
    27 Dec 2010
    30
    Thanks Received:
    Country:
    yes hot water tank. Label on top says immersion heater,
    I see , hot water taken from top so probly I only felt central of tank.
    i'll clean the plug thanks
  5. Notch7
    Notch7
    15 Sep 2017
    25,360
    Thanks Received:
    1,790
    S. Uplands
    Country:
    The immersion heater is the electric element -used as a back up heater in case your boiler fails, you are probably reading the end of the heater you can see on the outside of the tank, itll have a power cable going to it.
  6. andysink
    andysink
    27 Dec 2010
    30
    Thanks Received:
    Country:
    That's handy to know.
    Would it heat the tank if my gas failed? or is it some sort of general backup to get the gas part to do it's job.
  7. terryplumb
    terryplumb
    8 May 2017
    6,170
    Thanks Received:
    1,278
    Country:
    Yes ,the electric immersion heater would heat the water if your gas boiler failed.
  8. andysink
    andysink
    27 Dec 2010
    30
    Thanks Received:
    Country:
    Reading up on it. thanks
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
