can self levelling be put on top of self levelling
12 May 2009
I have had my quary tiles lifted to find crumbling top layer of concrete underneath concrete was ok. Its the been screeded with sand and cement left overnight to dry and next day its had laybond screedmaster ultimate put over it. I have a few concerns
1.the council did not use a dpm under the screed he did put a bag infront of the living and dining room doors and screeded over them will this cause any problems no dpm and his bag method?
2.is it ok to use levelling compound before screed dry?
3 they did not prime the screed will that have problems?
4 they have missed some small patches I went out and bought some of the same stuff I got the milk and powder can I mix it up and relay over mossed areas and areas I think require it? Bearing in mind it is dry now
5. Should I primer it or do a bonding coat ? With what if so?
Why didn't he put a DPM in. He should of.
Yes you can use a levelling compound when screed isn't dry.
They should have primed yes. But you could put a liquid DPM ontop of the screed now. then another coat of Laybond ultimate
What floor covering is going down?
Probably nothing fixed so no tiles. Im quite keen on the vinyl laminate. I like laminate nice and easy to install however ive only worked with laminate mdf type not the vinyl so I hope its not any harded than the normal laminate. I bet now I've said that I will struggle. Can evo stik waterproof pva be used for priming its states on tub 1 part evo to 2 part water
