Yes.It's not totally clear, but does that label not say that the IΔn of the RCD is "0.3A" (aka 300mA)?
As three of us have said, probably the most likely cause of what the OP describes is that the cold water ius coming from the 'mains', not form the storage tank. If that is the case then rectifying that situation would be a third, and possibly adequate, option.I have both electric instant and a plumbed hot and cold shower and the plumbed one is so much better. What can cause a problem is height of the cold water tank ... so it would seem two options open to you.
It's not up to scratch - a 300mA RCD won't provide 30mA protection.As above, you'd need to check how much your max current can be.
Your service fuse could well be only 60amp, so plonking a 40A shower on there is going to stop you using much else at the same time.
If it is big enough, then you'd need a separate mini consumer unit to supply the shower itself, or a complete new consumer unit.
This would need doing by a registered electrician and I recommend you have one come and tell you what your options and the costs might be.
Have him use an RCD tester to check that the old Ottermill box is still up to scratch. It is the safety barrier for you and your family.
Indeed, I've already made essentially the same observation - i.e. that, even if it is 'up to scratch' (in terms of what it says on the tin), a 300mA will not provide any useful protection in the event of an electric shock (although it obviously may clear a fault before anyone has a chance to get a shock).It's not up to scratch - a 300mA RCD won't provide 30mA protection.
He did, but he also said ...TTC did say a new shower CU would be required.
Was he perhaps assuming that it was a TT installation and that the 300mA RCD needed to be 'up to scratch' to provide ADS ("the safety barrier for you and your family"), rather than 'personal protection' (the latter being what I thought he meant)?Have him use an RCD tester to check that the old Ottermill box is still up to scratch. It is the safety barrier for you and your family.
Many will claim that you can't have a usable gravity shower with that little head - in practice, it's going to be around 6 feet of head. While it will never be "invigorating", you can get a perfectly usable shower (I used one for many years) - with the right parts.... if in the loft then should be OK without a pump ...
I was merely trying to translate "Have him use an RCD tester to check that the old Ottermill box is still up to scratch" for John who, strangely, can decipher meanings from near gibberish but not clear writing.
He probably did (albeit 300mA seems unnecessarily high, even if it is for ADS in a TT installation) but it was his following sentence which led to the comment I made ...I presume he just meant to show it still works and if not, replace it.
Maybe I'm wrong (again), but I took that as a reference to 'personal protection' (for which a 300mA, or even a 100mA, RCD would obviously be pretty useless), not to ADS. Do you disagree?... It is the safety barrier for you and your family.
