    Dismiss Notice
Can you skim a small section of a wall?
Discussion in 'Plastering and Rendering' started by splatty93, 18 Jan 2015.
  1. splatty93
    splatty93
    18 Jan 2015
    2
    Thanks Received:
    Country:
    We have a wall that has a crack all the way up from being damaged by a door banging into it. Have tried to fill the crack and sand back with polyfilla but this has just made it look worse.
    The damaged section behind the door is 1m x 2.5m but does join to a bigger wall above the door frame. Can we just get this section reskimmed or do you have to get the entire wall reskimmed?
  2. Sponsored Links
  3. gregers
    gregers
    28 Mar 2008
    6,301
    Thanks Received:
    500
    Sussex
    Country:
    yes you can aslong as the rest of the plaster is in good condition.
    • Thanks Thanks x 1
  4. NickB_99
    NickB_99
    25 Oct 2008
    1,166
    Thanks Received:
    141
    Cheshire
    Country:
    As gregers.
    If your wall that is being banged into is a stud wall and boards not secure, may need some screwing of boards before re skim.
    Alternatively, put a doorstop into the floor to keep it clear of the wall.
    • Thanks Thanks x 2
  5. WalksWithTurkeys
    WalksWithTurkeys
    13 Jun 2011
    1,234
    Thanks Received:
    85
    Hampshire
    Country:
    Why did Polyfill make it look worse? Anyway, it is horrible stuff, hard to sand. Buy some Easyfill, rake out the cracks, apply easifill, when dry apply more if needed as it shrinks a bit. Then sand smooth. Sorted.
  6. splatty93
    splatty93
    18 Jan 2015
    2
    Thanks Received:
    Country:
    To be honest the crack isn't even that big. Where I've polyfillaed over it it's created extra depth out from the wall and can't get it back to flat.
  7. gregers
    gregers
    28 Mar 2008
    6,301
    Thanks Received:
    500
    Sussex
    Country:
    the best way to fill a crack is the gouge it out and make it bigger then fill it and smoothe it flat with the rest of the wall.
    if you just fill it over the top of the crack your just adding more material to the problem.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
