In the 1960s the. Used BA screws
The property has been part rewired. However the lighting circuit went untouchedHas the property been rewired, if not there is a good chance the lights will not be earthed, could cause some issues if metal lights or switches are fitted
Thank youIn the 1960s the. Used BA screws
So just to confirm, i require '4BA' screws as suggested by @flameport?Something like this but I’m guessing.
Maybe someone else can confirm.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/371148856522
They can be cut if required
Cut them?I've done that before.
The rethreading tool will help you to form a thread to help you getting the new screws in.@sparkwright top man!
Just so that i have it right, after inserting the yellow plugs, i should use the 3.5 rethreading tool inside the yellow plug?
If the screw is too long, what could happen?
I threw out the old screws.. i assumed that all back boxes (especially in a home built in the last 60 yrs) would use 3.5 screws
Yes a good idea but it really should be a 2.8mm drill for m3.5 thread.They maybe not be gone. If using too small screws that’s maybe the problem.
See at 6 mins.
And interesting idea.
