Capping a gas pipe
Status
Not open for further replies.
3 Sep 2008
West Midlands
If anyone could help with this please.
I need to cap a gas pipe which is no longer in use after a set point. I'm wondering should i use a stop end or the compression type cap? I have both but a little unsure which would be best. Pics below show the pipe and fittings.
View media item 9247 View media item 9248
There is a gas cooker on the left of my pic. I would cut the pipe coming from the left just before the elbow connector (red circle) and attach the stop end. Obviously i would shut the gas off from the meter before starting. But after making the cut do i need to do anything else or wait for the gas to clear etc?
thanks
where do we start! carry out a let by test and complete a tightness test if let by test ok attach continuity bonds and remove and cap gas meter and place in ventilated area, and blah blah blah but on a serious note if you ain't qualified or competent do not even attempt to do this kind of works :eek:
If your having to ask about what to do then you really shouldn't be working on gas pipes.
Consider using a registered gas engineer for this.
It shouldn't cost you much.
Andy.
Status
