Car creaking noise at low speeds
7 Dec 2018
My son's Corsa e has had new inner and outer tie rods, new drop links as well in the last year. In the past month at low speeds it has made this creaking noise especially when turning, you can just feel it on the top mount and the outer tie rod on the driver's side but I'm at a loss to know what's causing it. You can only just feel it and I'm assuming it's not the new parts. Anyone have any advice?
The car has to be moving to hear the noise and it's louder in the car than outside
Try this....jack the car up, feel the spring when someone turns the steering wheel for you. This shows up any strut top bearing problems big time!
John
John
Can I assume that advice goes for any make of car with strut top bearings or specifically related to the OP's model ?
For sure, any Macpherson strut system can be checked this way.
Another sort of trick of the trade - if you suspect a wheel bearing fault for example - which often doesn't show up as play - grip the spring and spin the wheel.......you'll feel a thrumming through the spring. Front or rear too!
Regards
John :)
Regards
John :)
Many thanks John, my reason for asking is that my old 1998 5 series has an intermittent clonking noise from the front end, when driving over a damaged road surface, for over a year. now. Struts/coil springs/top mounts were renewed by a classic restorer 3yrs/16k ago & the car has since been through 2 MOT's without advisories.
I think when you have changed the usual suspects such as drop links and arb bushes the top mounts are the only thing left really.
My last 2 cars have had annoying knocks that were eventually tracked down to worn top mounts, a real pita to diagnose and overlooked as they are not easy to change without decent spring compressors on some cars.
Just sold my dad's old 2005 merc c class and compressing the front springs on it normally requires the official merc tool as you compress them on the top mounts due to the spring length, I managed to do this with my tools but it was sketchy as hell.
Thanks, compressing the springs is hairy. I've got some spring compressors and did it on my Corsa after one of the springs broke.
At the moment it wont allow me to upload these files which are M4A. If anyone knows how please let me know.
