We are about to order some underlay to go with a new Seattle Lavastone carpet in a bedroom. The carpet is 16mm Saxony pile with an Action Hessian backing.
I am also going to staple the underlay to the wooden floorboards.
Thank you
- Is Cloud 9 Cirrus 9mm thick underlay suitable? Tredaire has a similar spec but I can get the Cloud 9 cheaper.
- Is it ok to lay the underlay in the same direction as the carpet? This would avoid a narrow 30cm strip.
- How often does the underlay need to be stapled? I’ve seen YouTube videos where it the underlay is stapled every 40 cm right across the room - while others just staple around the edges?
Thank you
