turned out to be a long post
My son has just moved into a flat
On monday we noticed a Very wet patch about 9" diameter in the middle of the room ( Bedroom) - we assumed this maybe the previous owner - cleaning the carpet and a stain before leaving - as the property was spotless and clean through out
We have tried to contact the previous owner and had no reply yet
so we lifted the carpet
and the underlay was wet on the top BUT the bottom of the underlay was dry and so was the concrete
took the carpet out completely
and the underlay was perfect all over
This morning - there are a couple of wet spots on the underlay
Like a bowl was left on top and the water spilled - The boys had been cleaning all the walls and skirting board and they are sure NO water was spilled out of the bowl - but thats what it looks like
We lifted all the underlay and the concrete floor is fine No sign of damp and no change of colour anywhere and dry
Its like some dogs have relived themselves in three spaces
Or water is dripping through the ceiling
or a bowl with a small leak has been left on the various patches
No real damp smell
the underlay at the bottom is a white/cream/coloured material and its perfectly clean and no water - the top paper cover is very wet - you could ring it out
i throw some water over a patch on the top and that was the same after 4 hours
wet on top and dry underneath
I'm confused - I would expect to see
1) change of colour on the concrete floor
2) mould or green on the bottom of underlay
3) mould / black on the walls or skirting board - which is all perfect
4) we have rubbed down all the wood work and walls for painting and nothing is showing any sign of damp
5) all the edges are fine
6) No cracks or patches on the concrete at all
7) the patches of wetness on the underlay this morning was not in the same area as the wet carpet
No water in there only the pressurised central heating - so if a pipe has leaked then that would let out a lot of water and we should have seen the pressure gauge on the boiler go down
nothing
the dampcourse is 3 or 4 bricks above the ground with airbricks
nothing covering the dampcourse
BuT again I would expect an issue on the walls
I'm at a loss - we are leaving the underlay but folding back in the patch areas to see what happens tomorrow
any ideas at all please
No real damp smell
nothing
