I'm trying to get my head around setting up a Euro 46 to do area set.
The scenario is a small factory that has decided to sub-let the upstairs of an office block. These will share a common lobby area.
I need to reconfigure the panel such that the tenants can only unset/set the sensors in their space (hence leaving the main factory set) but the factory staff and unset all the zones.
The bit I don't get is.... If the tenant unsets the panel & then the factory staff arrive later...... what triggers the second entry/exit to cause them to enter a code to unset the main factory?
Also, the EURO46 has areas 0, 1, A, B, C D. Whatis the difference between areas 0 & 1 and A, B, C, D?
Thanks in advanced for your help - I've installed many a panel in the past but this is the first time I've need to configure one for anything other than full set!
Adrian
Adrian
