I need to build some blockwork walls and I want to get the mortar thickness right. The blocks will probably be medium density 140 mm thickness.
Has anybody used the Brikmat system from Catnic? It's not cheap, adding about £3 per square metre to the wall cost, but I like the way that you can slap a bit too much mortar on and then compress it down to the right thickness.
I have reasonable DIY skills but no experience of building walls so anything that helps me to deliver a good, robust job would be good. Does Brikmat fit the bill?
AA
AA
