Cavity gap next to upvc window
25 Nov 2007
Hi, Im decorating my hallway, on doing prep work found crack around window frame but in the corner by internal sill there is a large gap about size of tennis ball and can see the cavity, whats the best way of dealing with gap as I need to have it ready for a plasterer?
regards
From my understanding expanding foam is the answer. If the foam willcome in contact with the double glazed frame, then you should use a window foam filler, so that is does not react with the frame.
Use a search engine to Check out foam fillers types and usages
