I have a cavity wall mounted meter box which has a 15mm supply routed through the back, into the house supplying a gas fire. The pipework is behind the plasterboard.
I would like to have GCH installed as it's currently storage heaters. This would need a new 22mm supply from the meter, through to the back of the house.
Is it possible to make a hole in the front edge of the meter box so the new 22mm pipe can be run along the outside of the house? Or will I need to remove the plasterboard inside and run it?
TIA.
TIA.
