cctv over distance
18 Feb 2006
Birmingham
Hi all
Going to be fitting a new cctv setup(low/mid end) for my house, following a recent burglary. I am adding 2 cams to the front and 2 to the rear.
Now I want to add another one to the shed, which will face the rear of my house, but the only problem is that its about 25m away from the house. All cameras will be wired day/night ones fixed to house walls, so it will be easy to wire into the loft. The shed one will be a pain
Is it possible for me to send the video using homeplugs? Plan was camera in the shed to balun connected via ethernet cable to the homeplug (plugged into socket). Then in the house from homeplug to balun to camera. I can connect power supply for the camera at the shed end.
This would just mean everything is recorded using 1 dvr and can be accessed remotely easier.
No.
'Homeplugs' send an ethernet protocol over the mains wiring instead of over balanced UTP cat5e cable. Ethernet being the network TCP/IP protocol for computer networking.
BALUNS do not use ethernet - they just use the BALanced pairs of the cat5e cable to send the UNbalanced composite CCTV over. (actually just a single pair of the cable).
You could go wireless, but it's never going to be the same as using cable unless you invest heavily.
