    Dismiss Notice
CCTV x 6 cables, TV, Sat cables x 2, and Ethenet cable...?
Discussion in 'Alarms, CCTV & Telephones' started by GazSuttonUK, 12 Jan 2020.
  1. GazSuttonUK
    GazSuttonUK
    20 Oct 2006
    161
    Thanks Received:
    West Midlands
    Country:
    Ive got my lounge gutted at the moment and about to chisel out for back boxes......and Im completely lost on what wall plates to use to fit:-
    TV Arial(Freeview) x 1
    FreeSat cables x 2
    Ethernet cable(for Firestick)
    CCTV cables x 6
    Many thanks for any help...
  2. Sponsored Links
  3. OwainDIYer
    OwainDIYer
    5 May 2010
    4,501
    Thanks Received:
    686
    Stirlingshire
    Country:
    Do you actually need to bring 6 x cctv cables into the lounge? Usually one video cable from the DVR and a mouse extension if appliccable. Or modulate the camera feeds onto TV channels if you want individual cameras selectable from the TV. Aerial and Sat can be on F connectors (and you can duplex TV, DAB and FM Aerial on one of the Sat leads), CCTV will usually be on BNC.
    • Thanks Thanks x 1
  4. mattylad
    mattylad
    27 Apr 2008
    7,067
    Thanks Received:
    438
    Country:
    double or triple up on the ethernet cable, there are often other things that want a connection to the router (where is that?) such as PD4, Xbox, TV and so on.
    Fitting more cables will save the pain in the future.
    As above, CCTV in the lounge? I'd rather have my CCTV setup hidden away somewhere safe and feed a single display connection + ethernet to it than have it all sat there ready for someone to pinch should I get burgled. The wife would hate having to dust it all too. (not that I have cctv).
    • Thanks Thanks x 1
  5. GazSuttonUK
    GazSuttonUK
    20 Oct 2006
    161
    Thanks Received:
    West Midlands
    Country:
    Thanks for your replies....Im new at this CCTV stuff, so I could have one cable from the DVR that goes into the loft and devide that cable in to 6 or 8 cables to go to the CCTV cameras?
  6. Handymanjo
    Handymanjo
    2 Feb 2016
    1,494
    Thanks Received:
    280
    Newark
    Country:
    1 cat5 e max 4 camera
  7. Sponsored Links
  8. GazSuttonUK
    GazSuttonUK
    20 Oct 2006
    161
    Thanks Received:
    West Midlands
    Country:
  9. Sally2000
    Sally2000
    6 Feb 2013
    358
    Thanks Received:
    33
    London
    Country:
    You don't divide the cables. Each camera connects to its own port on the DVR.
  10. GazSuttonUK
    GazSuttonUK
    20 Oct 2006
    161
    Thanks Received:
    West Midlands
    Country:
    So two wires per camera.....equals 4 cameras per cable?...……...and could I use that wall plate above?
    Cheers..
  11. Sally2000
    Sally2000
    6 Feb 2013
    358
    Thanks Received:
    33
    London
    Country:
    Just one wire from each camera to the recorder, if you are using POE. And HDMI from the recorder down to the lounge.
    That plate may be a tidy way to bring your various network connections out to the lounge.
    At some point you may need an ethernet switch/splitter, unless your router has sufficient ports. Most basic ISP provided routers are limited to four ports.
    • Thanks Thanks x 1
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
